I,m starting to notice a little corrosion around the port chainplate.I,m going to remove it and check things out but need to know how big of job it is to remove it.
What make & model boat? Is the mast up? What do you mean by corrosion? Is there any water leaking inside of the boat? If you can answer these questions, you'll get the answer you're seeking.
