Chainplates
shine
Sep 14, 2009
74
Macgregor 1985 25 ft. Macgregor swingkeel Mo
I drilled out rivets and installed machine bolts. I used butle and it still lets in water. I’m considering cutting a small section of rubrail off glassing over the holes and mounting chainplates on outside of hull. What do my good friends on this forum think about that. Am I crazy. The port side doesn’t leek right now.
dmax
Jul 29, 2018
1,260
Telstar 28 Buzzards Bay
If butyl is leaking then you didn't seal it correctly or you something's moving - countersink/bevel any holes and make sure you have good coverage. Gradually tighten it up over several days to allow the butyl to work in and ooze out. Will not leak.
chp
Sep 13, 2010
434
Hunter 280 hamilton
I did mine about 7 years ago and never had a leak since. I jammed a lot of butyl into the gap around the chainplate.
shine
Sep 14, 2009
74
I have tried butyl twice on starboard side with no luck. I think in the spring I will give the 4000 or 4200 a go. Thanks for the reply’s.
Sep 24, 2018
4,048
Catalina 30 MKIII Chicago
If you post a picture we may be able to identify why the butyl isnt working. It's usually much easier to work with than 4200
