Phil
My 1975 Oday 27 has developed cracks 1" from the perimeter of the lower shroud backing plates inside the cabin. A marine surveyor checked it out and said that the deck is sound and no delamination is evident. The shroud tension is a little slack but the chainplates seem firm.It appears that the this is a crack between the liner and the build up around the backing plate. I was planning on grinding this off to inspect the interior and then build it back up. If the interior is sound on one, I thought I might just route out the crack on the others and inject epoxy into it to reattach the liner with this backing area.Has anyone had this problem before or any better solution ideas.
