I was able to spend Friday on my H37C. This has been a bad winter for bilge water. The yard did not get the cradle level so that I have standing water on the decks. Except when it was frozen of course.A lot of that water came in through the mast as usual. But I also had wetness around the toerail bolts and chainplates. So I decided to tackle that on Friday after I installed the vanity sink(other post).I wasted 20 minutes trying to dig out the old sealant with the cover just an inch off the deck. I finally bit the bullet and loosened all the shrouds. Then I took off one shroud at a time and tied it off to the toerail. With the cover plate off it took at least 30 minutes per chainplate to get the old sealant out of that hole. You wonder how it could leak! That stuff is tough yet the water gets in.I refilled the hole and built it up with Life-Caulk, the same stuff I use for the portlights. I used enough that it pushed out the edges and in the middle when I reinstalled the cover. I am considering making new covers that are split but overlap. Something that you could take off without removing the shrouds. Anybody done that? Now I have to borrow a Loos gauge and retune the rigging.I know that toerail bolts are supposed to be tightened by holding the bolt and turning the nut. The theory is that you do not want to turn the bolt and disturb the sealant. Well I work alone and I know there is no sealant if there ever was any. So I tape a box end 1/2" wrench to the bolt and side of the hull. Then I go up with a very large phillips and vise-grips and tighten from above. It is slow going but I really get them snug. I have considered some kind of large wing nut where the "wing" would jam against the hull. Then I could tighten easily and often. I have doubled up a few with fiber locknuts. Not sure if that will prevent further loosening. Another fine day on the hard.
