Hi and happy new year.
I'm in the process of removing my chainplates on a 1984 Alden 44. I have already disassembled most of the saloon cabinets and can access and remove the bolts. I now need to lift the chainplates out so they can be remade with a water jet (I've already decided just to replace them all given their age). They are very tightly bedded at the deck level with a solid material. I'm guessing either bedding compound or epoxy resin (see photo with gray material at tip of plate). They are very solidly in the groove. I even hit with a hammer and they didn't budge at all.
Has anyone encountered this? How did you remove them? My first impulse is to use an oscillating saw with a plunge blade and cut as close to the plate as possible. Open to other ideas.
