Tony
Have a new Catalina 350 (hull 166) and have a question about the windlass. Do you need a chain stopper? The windlass manual mentions it but the setup provided by Catalina does not have one. I loaded the line and chain and when using the windlass to bring in the chain it seem to rub against the anchor locker door (which was raised). I was using the starboard roller and loading the chain into the port section of the locker. Is this normal?When bringing up the anchor the first time there was a good deal of tension on the chain between the anchor roller and the windlass. I backed the windlass off a little (but it's still fairly tight). Is this the right thing to do?Thanks in advance for the help...Tony
