chain links
Nov 26, 2008
1,970
Endeavour 42 Cruisin
I'm striking out looking for a chain connector for 5/16 G4 chain.
Some of my chain rusted sitting in the locker. I have a fresh 70' I would like to use to replace the bad section. Nothing I find is suitable for strength or durability. I can deal with one link that won't fit thru my windlass, I have that figured out. But the strong links I find are zinc coated not galvanized.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
can you find a repair link that will work on your gypsy if so use it and weld it after it is install and dress it down with a file
Mar 20, 2012
3,983
you need to look for on in a place where they supply goods and tools to the "working" marine industry, as opposed to the "sport" industry....
try a marine rigging store, NOT west marine, something like englund marine supply, fisheries supply, or a logging supply store that is located near the coast.... a galvanized connector is not an uncommon part...
do a search for "crosby missing link" and you will see what you need.... then locate the right model for your particular chain....
Nov 26, 2008
1,970
I'm dealing with 1st chain supply, a very large dealer of chain and rigging. They have 4 or 5 different styles of links.
I have G4 chain. The links won't fit on G4 5/16.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
gettinthere: Zinc is galvanized. You can split hairs but the heating concept is the main factor as far as I know. Chief
Aug 15, 2014
114
Catalina 36 Deale, MD
Purchase the zinked link and galvanize it at your local plater. They will probably do it for free just for the story. Else charge you $10.
Mar 1, 2012
2,182
Check the WWL and breaking strength if the chain link compared to the chain itself and you anchoring system design. You may be able to use a 1/4" chain link.
Tables are here:
Anchor System Sizing Tables (Reply #6) & Swivels http://c34.org/bbs/index.php/topic,4990.msg30400.html#msg30400
5/16 G4 chain has a safe working load of 3900 pounds. 1/4 G4 has a safe working load of 2600 pounds.
I have 1/4 G4 on my boat. and nowhere can I find a chain connector for 1/4 that comes up to 2600. Let alone 3900.
A 1/4 inch connector might fit, but I certainly wouldn't use it.
Dec 25, 2000
6,052
An Alternative Solution
Our boat came equipped with a 40# Danforth, 30 feet of 5/16" grade 40 chain and 250 feet of 5/8" three strand nylon. When we first purchased the boat in 2002 I had some anchoring lessons to learn.
Those lessons have helped make what I consider to be a very effective anchoring system suitable for just about any occasion. Still have the 40# Danforth. Very effective in PNW waters. Also, still use a 20# kellet (lead down rigger ball). So, Belle-Vie has 50' of 5/16" grade 40 chain, 150 feet of 5/8" three strand nylon, another 50' of 5/16" grade 40 chain and another 150 feet of 5/8" three strand nylon. Each is connected to the other using a warp splice.
Typically I shoot for 25 feet of water to drop and set the anchor. Usually settle with a minimum of 110 to 140 feet of rode unless sour weather is in the forecast. A SS carabiner secures the kellet to the end of the first 50' segment of 5/16" chain. This helps with catenary.
Catenary is also the reason for alternating between chain-to-rope to chain-to-rope. This tip came from another seasoned sailor that seemed to make sense when lots of rode is needed for much deeper water and/or sour weather conditions.
Beneteau 323 Annapolis MD
...Catenary is also the reason for alternating between chain-to-rope to chain-to-rope. This tip came from another seasoned sailor that seemed to make sense when lots of rode is needed for much deeper water and/or sour weather conditions.
The same system was in one of the sailing magazines a couple years ago, but I think it was 50/50/50/50 feet. It sounds reasonable for most places, but not all. YMMV
