how do i force down the centreboard from inside the cabin of my 1971 Oday 23 - wire pendant variety ? I cannot seem to get anything down inside the post in the cabin. Thanks
I don't think that there is any way you are going to get the centerboard down from the inside. The keels on the older O'Day 23s before 1974, were made of cast iron and chances are the keel slot is caked up with rust, preventing the centerboard from moving. You will need to get at the centerboard from under the keel somehow. For more info on this, check out this site. http://baysailorbill.spaces.live.com/ Bill had an O'Day 23 with the same issues and he was able to bring her back to excellent condition. I don't know why the O'Day people built the keels this way but they finally solved the problem in 1974 when they started building the keels out of lead. These are still great boats and they will still sail without the board, but the upwind sailing is better with the board.how do i force down the centreboard from inside the cabin of my 1971 Oday 23 - wire pendant variety ? I cannot seem to get anything down inside the post in the cabin. Thanks
Nate,I've heard of people using pry bars from down below. I've also heard of using a steel rod down the trunk. Not sure on our boats though, i've not had mine apart to be able to tell you for sure.
That's great. You're all set then. It doesn't hurt to check the pendant connection on the board every year though. Mine is pretty good this year, but last year I found a broken cotter pin on my shackle and had to replace it. Have a great sailing season Nate!Mine is ok, it's a fresh water boat. I can hear it clunk on the trailer when I pull on it.
With the right equipment, you can get the boat off the trailer. Roller trailers make it easier but I am able to get my boat off my tandem bunk trailer with four sailboat stands under the stern. I use a hydraulic jack under the bow and place a straight power boat stand under the bow close to the keel to hold the boat up while I move the jack. I'm able to move the trailer out from under the boat about two feet at a time because of the trailer's cross members. I also use 6"X6"s and 4"X4"s criss crossed under the hull to help carry the weight. Once the the keel is past the back of the trailer, I use criss crossed wood blocks to support the boat under the keel and pull the trailer out from under the boat. After that, the boat can be raised with the five boat stands spread out in the normal fashion. I usually block up under the stern and the bow as I raise the hull. The bottom of my keel is about about 22" off the ground right now. I've had it as high as 27" off the ground.I wish there was an easy way to get the boat off the trailer and inspect it like you said. I'm sure it needs to be gone over like everything else on this boat. But I do know its free and clear in the keel.
Jonathan,Hi Joe.
Thanks for this. Unfortunately Bill seems to have shut down the link.
You are right, it is a cast iron keel. Some years ago, when working in Haiti, I had the boat hoisted from a warehouse roof to try and clean out the slot. It was impossible to get at the rust inside - you really need some sort of long blade grinder, but I did my best and ended up replacing the centreboard, which worked once until I guess the rust built up again. I'm not sure what the long term solution is.
Jonathan
Jonathan,Hi Joe.
Jonathan
Nate,If people are interested in all the pics that Joe sent me - I can host them on my site for download. That is, if Joe doesn't mind. There are some good hand drawn pics of the center board wedges, etc... As well as actual pics of the keel slot and what you are dealing with when attempting repair.
