The centerboard to my boat is made of galvanized steel and weighs 203 pounds, and the pendant wire is detached from the centerboard. The attachment broke off. The pendant wire is either still in the shackle (of some sort) and the shackle broke off completely OR the shackle is still attached but it's partially broke. Whatever the case, the pendant is not where it is supposed to be. For those of you who have worked on centerboards, what is the likelihood that I will be able to see and have clear access to the wire pendant? And secondly, how can I attach the loop end of the pendant wire to the centerboard? The shackle most likely snapped from a combination of corrosion, age, and pressure and I am guessing that some of it will probably be still on the block (swage? How do you think the pendant was attached?)? Will there be anything on the centerboard that I can crimp (with nose pliers) through and around the wire loop? And one more thing, how difficult will it be to do this job underwater providing that the water is fairly calm? Has anyone here ever done this before under water?
