Centerboard sheave boxes
Richard
Where can I find replacements for the centerboard sheave boxes and assembly?
NYSail
Jan 6, 2006
3,184
Beneteau 423 Mt. Sinai, NY
Richard you there
was just wondering what your situation as with your sheaves.....
Dec 11, 2005
74
Pearson 30 Wanderer NA
I'd think twice about replacing the
bronze tube with rubber hose. I was tempted to do the same thing on my Person Wanderer but decided to renew the tube with bronze. If you replace the tube with rubber hose, if any section of the hose below the water line touches the wire cable during operation, the cable will cut into the rubber. Since the rubber hose would hide the wire, there is no way to insure that the cable was perfectly centered within the hose. If you do use rubber and the cable does start sawing into the hose, it is just a matter of time before you develop a leak that has the potential of sinking your boat.
NYSail
Jan 6, 2006
3,184
Ralph
Yes I am leaving the bronze piping in the system as with new unions and a correct instalation, they will be easy to service when needed. I did not realize how thick these pipes were until I took the pendant run apart. Thanks! Greg
