Centerboard Replacement 1969 Mariner?
C
Chris Reinke
I am the original owner of a 1969 Mariner. I have recently experienced some problems with the centerboard not lowering properly (the first real problem I have ever had with the boat). I have found that the centerboard has begun to delaminate. The delamination has caused the centerboard to expand and it now gets fouled along the inside of the box. I belive the centerboard is in need of replacement. Any ideas or suggestions on locating a replacement would be appreciated? Is the centerboard for the new 192 comparable?
Dana
centerboard replacement
My Mariner has a steel centerboard, apparently it is not original. You might contact Stuart Marine in rockland, Maine. They now build the O'Day Mariner and have parts for the older models. 207-596-9975 Dana
Bob La Rocca
Mariner Centerboard
I don't know if this info helps you but here it is for whatever it's worth. I own a 1972 Mariner, my board which I took out last season to sand and paint is made of steel or iron and weighs about 200 pounds. A friend of mine has a 1969 and his board is also metal.
H
Henry Hey
Mariner Centerboard
Chris, I think this CB problem is fairly common in older Mariners. The first time we sailed our 67 mariner 3 years ago, the centerboard got stuck up in the housing -- after we had cast off (from a shallow launch) - A little scary. I had to take a long screwdriver to push it down out of the housing. This didn't last long. We finally decided to fix it. We took the CB out (be careful when you do this -- it's quite heavy). After you remove it you will see all this flaky stuff and what appears to be huge layers of the board itself seperating. We layed it down on it's side and removed all the flaking stuff. You can pound it with a hammer -- this usually helps to loosen it. We were worried about breaking it, but it really isn't an issue. These CBs were made of very heavy thick metal. After you get all the flake removed, try coating it with West Systems Epoxy. After refinishing the centerboard you will find yourself faced with another common mariner problem. Since you will have removed some of the expanding rust flake, the centerboard will now have much more room to move around in the housing. It may clunk from side to side. There have been many remedies for this listed on this site. You can try rubber washers on the sides of the CB (inside the housing) or read up on the other fixes. Good Luck. -h. hey
Rod Johnson,
Cast-iron CB
All of the O'Day Mariners with centerboards (there was also a 3' 3" fixed keel model, also cast iron) had iron centerboards weighing 165#. The later Mariners built by Stuart have a Fiberglass centerboard weighing about 75#. The O'Day Mariners also has 200# of lead in the bilge alongside the cetnerboard trunk.
