Centerboard pendant water leak.
1
- - Winthrop, MA
The centerboard pendant on my 1980 O'Day 23 passes from the cockpit through a flexable hose to the hull. When underway there's some water leaking into the billge and I suspect that the pentant has worn through the hose allowing causing the leak.
Anyone have this problem and what did you do to fix it?
Otherwise; a great boat!
Thanks,
Charles
Sep 20, 2006
367
Oday 20 Seneca Lake
i would change the hose for sure. i changed mine in my oday 20 as it was looking old and cracked. i used premium marine hardwall sae j 2006 100-1000-1" hose i found at the local marina. (yours may be a larger diameter.) the oday20 hose has a short run with two 90 degree turns. this was the only hose i could find that would make the bend without collapsing. also check the through hull fiting to make sure that is not leaking.
Oct 10, 2009
1,120
Beneteau 393 Muskegon
I've never seen a hose on mine, which is the same model/year. There is a stainless steel tube that runs from the bridge deck down to the keel, or so I thought. Where are you seeing the hose/tube, Aeolus?
