manual???
How do you replace the line on the center board / swing keel??
Is there a manual with all this type info in it?
Thanks AWOL1958
AWOL,
I am not aware of a manual for this type information. I have been messing around with medium sized sailboats for quite a while.
What there are, are brand specific email boads for sharing such infomation. Other boats will have similar set ups.
If you have line thru to board now, just affix small line to pull thru and then use small line to pull new line thru.
Otherwise, try pushing wire thru to attach string to pull line thru.
Also, if you have problems, post pictures of what your boat and situation looks like so others might comment.
Good Luck,
Ed K
