Center Board Inspection
N
Nick Sal
I just purchased a 23.5 Hunter. If one had to fix or inspect the centerboard uphaul connection, how would you do it? Everything around the mast step plate seems to be sealed.
C
Carl
you must remove centerboard
to inspect line, centerboard must be removed. check the archives a few guys here have done it recently
Ray Bowles
Nic, I removed the CB on my 95 H26 this spring.
The write up is in the Small Boat archives. It includes a neat trick to align the saddle when remounting this assembly. Ray S/V Speedy
C
Crazy Dave Condon
centerboard
Underneath the compression post you will find a cover plate. When that is removed, you will see a large bolt that should have caulk on it. To remove the centerboard, you need to remove the caulk and the large bolt. That will drop the centerboard out. Make sure you attach a line to the cascade or centerboard line if you intend to replace it. The safe way is to lift the boat up on a lift. Make repairs as necessary, paint and or replace cebterboarrd line. When replacign the bolt, make sure it will screw in correctly without force or you will strip it. Also, caulk the top of the boolt liberally. Crazxy Dave Condon
