W
William Putman
I recently removed my H22 from the lake for the season. Once the boat was perfectly center on the trailer, and out of the water, I noticed the center board resting on the axle/beam ever so slightly. At first I thought I didn't pull the center board the entire way up, however, when I pulled the rope, it was completely limp. It was then clear the cable had separated from the board. Based the diagram, it appears that the only way to repair the cable would be to lower the middle bunks on the trailer, drop the center board (i.e. remove pin) and bring it down, while still on the trailer. For the time being, I have secured the center board with a rope so that there is no contact with trailer. Do any of you know of an alternative repair method? Also, if anyone has repaired the center board before, I would be grateful for some direction. Thanks.Will
