Cell Phone Boosters
Apr 25, 2024
694
Fuji 32 Bellingham
OK, at the risk of hijacking the thread, this seems like a good place to make a confession. A few weeks ago, we were anchored out in the islands. I felt like streaming an episode of "Scrubs" on my laptop. I occasionally use my mobile phone as a wifi hotspot, connecting my laptop to it. This works really nicely when I have a decent signal.
But, where we were, the signal was just sketchy enough that we could sort of stream video, but only a few seconds at a time, between periods of buffering.
I came up with a clever idea. I put my phone in a waterproof dry-bag, clipped it onto the spinnaker halyard, and hoisted it up the mast. Still well within wi-fi range of my laptop, but now much higher to get a better signal. Worked brilliantly. We watched our program, then decided to turn in for the night. I went up to retrieve my phone and ...
In my defense, when thinking up this idea, I originally planned to tie a small line to the bag so I could pull the phone back down. However, in execution, I failed to do that. As it turns out, 40 feet of halyard is heavier than my mobile phone - a fact I had plenty of time to contemplate as I stood on the deck looking up and trying to figure out how to retrieve my phone.
I hear people asking, "Why not just ascend the mast?" I did indeed the equipment needed, and we were already safely anchored out. And, I've been up the mast on other boats plenty of times. But, we just bought this boat. The halyards are ... fine ... but we don't know their history. In fact, same with winches. I didn't bed them, so I don't know how well they are attached. No specific reason to doubt them, but not something I would bet my life on.
The next morning, we did manage to retrieve the phone without ascending the mast. Describing how we did it would be lengthy and it probably wouldn't help anyone. And, it is definitely off-topic.
Bottom line: This actually IS a good idea. It works quite well. It won't give you a strong signal where you have none, but it can give you just a little more, if that's all you need. But, do attach a retrieval line. And, if you forget to, at least make sure you don't have an audience. To do over again, I would retrieve the phone in the dead of night where the darkness masks my shame.
Jul 1, 2010
990
Catalina 350 Port Huron
We have a HI-Boost 2.0 travel unit. We use it on our boat, our travel trailer, and up at our cabin. It works pretty well, though you have to have a signal out there to boost. The only down side is that your phoone needs to be pretty close to the indoor antenna to get the boosted signal well. On the boat, I hoist the outside antenna up my flag halyard. Not enough cable with the kit to get it much higher than that with the booster unit inside on the nav station. We first tried a cheapie unit and it didn't work. Got this one as it had good reviews and may have been a little cheaper than the Weboost one.
Likes: jviss
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
That's funny. Thanks for sharing. Yea, I've been hoisting my phone for years, but always on an endless flag halyard that runs to a spreader.
I'm thinking if I get a booster I might just bite the bullet and mount the external antenna on the masthead, and get or make a cable to install in the mast, etc. I have power at the mast step, so mounting the internal amp and antenna will be easy.
Yes, on signal - you need something to boost! It's those situations where it kinda works that I'm hoping a booster will solve.
jviss
Feb 5, 2004
7,089
About hoisting one's phone up the mast: here's a story that really stuck with me. I was on a business trip to Monterey years ago, and went down to the shore. There was a group of kids there, and every now and then one would throw their phone up in the air and catch it. This was pre-smart phone days, just flip phones, etc. I went over and asked what they were doing. The explained they were texting with friends, but in order for the texts to go out, and to receive texts, the phones had to be higher up, so, they would throw them, and they'd come down with new messages, or having sent their messages. Pretty clever! :)
May 16, 2015
104
C&C 37 28127 Port Madison, Washington
Considering the WeBoost Marine package. I have a good marine wifi antenna already connected to some nav electronics. Thinking I might add a splitter from the antenna to A) cell booster and B) the nav (Cortex updates).
Question for those using the WeBoost, what is the amperage draw of the booster on your battery? Do you use it with an inverter? Do you keep the booster on or only while using? What are your best practices with the booster on 12v?
25
Sceptre 41 Vancouver
Cell booster antenna is different than WiFi.
Why pay for the pricy marine unit? Regular units are fine. (Likely technology improvements will require new booster before any corrosion occurs.
Our weboost is originally for an auto. 12v. Amp draw is 1.5 amps. Newer/current more-powerful Weboost boosters are 1.8amps (@12v). We keep booster on primarily when we are using it (and certainly not while sleeping...).
May 16, 2015
104
The antenna is the Shakespeare Galaxy wifi/cellular. Wilson just got back to me and assured me the WeBoost Reach will work with this antenna. I just have to get the cable length correct.
