CDI
H
HAL
Has anyone upgraded a CDI 2 to ball bearing from regular bearing? How did it work?
May 18, 2004
385
Catalina 320 perry lake
I installed a CDI on my last boat (Gloucester 22) with the ball bearing upgrade. It was easy to install and worked fine. Don't let anyone tell you that they are only good for furling. I used mine to reef all the time. Bill
JIM B
Jun 27, 2006
107
Catalina 30 MKII ROOSEVELT AZ
WORTHWHILE UPGRADE
I HAVE HELPED TWO PEOPLE UPGRADE THIER CDI'S TO BALL BEARING AND IT WAS SIGNIFICANTLY SMOOTHER. ON MY OWN BOAT I JUST INSTALLED GARHAURER STANCHION BLOCKS AND I AM AMAZED HOW MUCH DIFFERENCE THEY MAKE. GOOD LUCK.
H
HAL
Thanks. Making the line run with less friction might just do it. It's also good to know it can be upgraded if that seems necessary.
