The Wright Flyer's wing was like a sail having virtually NO thickness and the 'top' is/was just as long as the 'bottom' is .... as a sail is. The concepts of 'lift from a foil' that are taught in US public Highschools, etc. that explain that 'the air moves faster on the top side' is entirely WRONG ... and as was originally discovered by the Wright Brothers to be wrong.
The flow or air across a foil/wing is a vectorial CIRCULATING sum of flow and the lift is caused solely by that vectorial
circulating flow field because the air/fluid has VISCOSITY.
In all practicality, the flow of air, etc. across the 'low pressure' (lee) side has MORE flow, not 'faster' flow.
Air with unconstrained / unducted flow at atmospheric pressure is essentially non-compressible with changing pressure; so if incompressible it
doesnt 'speed-up' relative to the wing due to 'shape' and pressure differences! If the air 'sped up' it would be compressible at atmospheric pressure in 'open flow' ... and thats not the case.
Yup, generations of american public high school 'science' students, and a lot of pilots, etc., have been WRONGLY taught about 'lift' ... the 'curriculum' that includes this is and has been WRONG for almost 100 years.
Origins of LIFT:
http://www.arvelgentry.com/techs/origins_of_lift.pdf Although written for the 'layman' this is a 'hard' technical read for those without math / fluid dynamics backgrounds. You really have to have a 2 or 3 dimensional geometric perspective when reading this explanation.
