Caveat Emptor
Douglas Washburn
removehtml]In about six weeks, we will be taking delivery of and re-commissioning a 2003 H356. Obviously, our pre-purchase due diligence allowed us to be comfortable enough to buy the boat. What we are interested in knowing is are there any H356-specific issues of which we should be aware? We would sooner address them early than discover them one at a time over the course of the season. Thank you all for any comments you return. Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
Hi Douglas - great boat
Need to kick the mind into gear. One problem that is a hit or miss thing. I know of two owners who had hull flexing right bellow the shower floor area. The floor was cut out and a stringer placed to strengthen the hull. Hunter stepped up and fixed it. I didn't have this problem. Make sure your all ball valves have been swapped out on a recall from Hunter. They paid for everything. This happened in 2006 on several boat lines, it was a problem from the ball valve manufacture. I had a leak develop around the compression post. I remove the caulk and re-caulked the base plate under the mast. I've not had any problems other than wear and tear of my own making. Congrats and enjoy the boat. Jim S/V Java
Jun 5, 2004
485
Hunter 44 Mystic, Ct
Hunter 356
We had a 2003 356 for three years and it was a great boat. You will be very happy. After the second year we noticed a slight 1/8 inch gap between the hull and leading edge of the keel. Had to have the keel bolts tightened and had a piece of fiberglass reinstalled around the keel to hull joint. No problems after that.
Jun 7, 2004
265
- - Milwaukee
Great boat
It's a great boat. I'm very fond of ours. Check for hull flexing as Jim mentioned. Look for signs of water aft of the main berth, on the shelf or that bulkhead. There's some sort of odd leak related to the cockpit, and water collects in the curled lip of the headliner, spills out when you heel. Oddly I had a reefing line burst this summer, might want to check those if it's the conventional model. But after 5 years, the plusses far outweigh these few nits.
Bob R.
Jun 5, 2004
161
Marlow-Hunter 40 Pasadena, MD
Water in Aft Cabin
I have a 2002 356 we purchased last May. I found water had leaked into the aft cabin and soaked a blanket and some clothes I left on the aft shelf. The leak happened during a rain storm while with boat was tied up in its slip. I have never been able to determine where the water got in. I have also had problems with a leak at the compressin post. I tied a rolled up wash cloth around the post at the head liner cover until I got around to removing the headliner cover and caulking around the deck penetrations for the wires entering from the mast and caulked around the stainless steel deck base plate as Jim noted. That seemed to stop the leak. Our surveyor found water stains on the inner hull below the hull/deck joint behind the hanging locker in the aft cabin and in the the storage lockers on the swim platform. The PO agreed to have a boat yard in Annapolis remove the rub railfrom about mid ship around the stern, caulk the joint and re-bed all the retainer screws. I am not convinced that was necessary, but PO agreed to pay for it as part of the sale. Great boat. Lots of room and storage. Easy to sail. Very comfortable for overnight cruising on the Chesapeake. Bob R Unfurled H356
Steve
h356 issues
We also have a 2003 H356 which we bought in 2005. In addition to what the other folks said I would add the following. Had a small leak which showed up under the V-berths just forward of the access doors under the V-berth. Turns out that there was a small void in the bow that allowed water to enter the area under the anchor locker. Thought that the leak was in the locker until we removed all of the V-berth structure and played a hose on the bow. The fix was a little epoxy to seal the leak. Our boat had sat in a yard for well over a year before we bought it. It was probably not blocked perfectly and, as a result, the fold down helm seat would only rest on one of the little bumper pads. Made a thin shim out of Starboard to fix the problem. At the same time we replaced the self tapping screws that secure the fold down seat hinges with through bolts. We also have a minor leak around the compression post and sealing that area is also on our list of things to do. This is all pretty minor stuff and pales in comparison to how well the boat sails, how comfortable the cockpit is for large day sailing groups, and how comfortable she is for overnighters.
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Jim-Java, ball valve ?
Jim, what year were the ball valves recalled? I thought that was to replace gate vales with ball valves on much older models. I didn't think it was recent production?
Bill O'D
To survey or not...
Everyone recommends that you get the boat surveyed, but I've never done it. My own thorough exam has usually proved sufficient, and I stick with boats five years old or less. My theory is ridiculous, but I find the survey analagous to running a credit check on one's fiance. It could spoil the love.
Terry Cox
Hi Bill, I hired a certified marine surveyor in the...
two boat purchases we've made. I figure four eyes are better than two, plus he has lots of marine survey experience. I followed the surveyor around every step of the way and asked lots of questions. In our case he used a moisture meter. Afterwards both the insurance company and our lender requested a copy of the survey. I'm glad I hired him. Terry
Mar 21, 2004
2,175
Andy here is the letter from Hunter
You can also find the 2 page notice on the Hunter Marine website - see link below Jim August 11, 2006 Dear Hunter owner, It has come to our attention that a particular brand of ball valve installed by Hunter Marine in the boats bearing hull numbers listed below may fail under certain conditions or after an extended period of time. The suspected ball valves in question were manufactured by Marine Hardware and are most easily identified by their blue handles and the drain / grounding screw (please see attached photos) incorporated into the body. Failures have taken place when the ball valve stem corrodes prematurely leaving the handle unable to close the internal ball. If the valve cannot close, the connections may lead to water entry. Due to this possible failure, Hunter Marine has decided to voluntarily recall this brand (only) of ball valves. This voluntary recall is being launched and monitored under Coast Guard campaign number 060053T. The models & hull numbers in question are as follows and involve only the ball valves as described above: H240 - HUN24462F203 through HUN24516C404 H260 - HUNF0027A202 through HUNF0140B404 H270 - HUNK0162F102 through HUNK0173D304 H27 - HUN27101G405 through HUN27105J405 H306 - HUN30465F102 through HUN30568C404 H326 - HUN32255F102 through HUN32362I304 H33 - HUN33101I304 through HUN33258J405 H356 - HUN35101F102 through HUN35421F304 H36 - HUN36101F304 through HUN36231J405 H38 - HUN38101C405 through HUN38145J405 H386 - HUN38718E102 through HUN38836C404 H410 - HUN41332K102 through HUN41357H203 H41 - HUN41101J102 through HUN41218J405 P420 - HUN42189J102 through HUN42230J304 H426 / 44 Aft Cockpit - HUN4A101G203 through HUN4A155J405 H426 / 44 Deck Salon - HUN4D101D203 through HUN4D196J405 P450 / 456 - HUN45272J102 through HUN45315I405 H460 / 466 / 46 - HUN46270G203 through HUN46337J405
Jun 30, 2004
446
Hunter website
Jim, thanks for the letter. After I posted I went to the Hunter Factory website to double check the valves on our 340 since we bought it used. Nope, no 340s under the old name or new name need new valves. Which brings us back to Doug's situation of Caveat Emptor- Doug, you can go to the Hunter Corp. website and check for recalls and you may want to make sure they have a record that you are the new owner of H356 #yayayy. This website will tell you plenty as the BPs come along (Boat Projects). Good luck have fun and enjoy a boat that for many of us is the "next boat"!
Douglas Washburn
I checked...
with the broker from whom I bought the boat. His records indicated that the valve recall had been exercised. Thank you, Jim, for mentioning them.
Mar 3, 2003
710
Hunter 356 Grand Rivers
One of the best 36 foot boats ever produced!
I haven't had any real problems with my 356. I bought it new in 2003 and we will be on our 6th season in March. I too have an occasional small leak in the Master Bedroom on the shelf - have yet to find the source. A few things I did to make mine better are as follows: Put a drain in the HVAC condensate pan and pipe with plastic pipe to the shower sump for HVAC condensate. It drains into the bilge if you don't. Take a saw and make the panels under the salon seats fit the shape of the cushions - it will make accessing the storage there and checking the HVAC much easier. This only takes a few minutes and some hinges. Change out the Jabsco toilet to a Raritan Sea-era electric model. The original toilet is not very good quality. We have never been able to have a dry bilge, so this year I am installing a pss shaft seal. I wish I had done that earlier. Weve got about every improvement you can put on the boat including generator and tracking satellite tv. We use it about 75 to 80 days per year. I spent 3 weeks on a Cabo Rico 38 this fall from Ky Lake to Punta Gorda, FL and there is no comparison with the amount of room available on the 356. The 356 is much larger and more comfortable and feels like a 40 to 42 foot boat! I think it is one of the best designs for a 36 foot boat ever produced. Hope you enjoy yours as mnuch as we have.
Mar 20, 2004
1,753
great boat all around!
Ditto to all of the previous comments! We bought our '02 356 new and except for a few teething problems and the minor leaks above, she's been great! Can't say enough good things about Hunter's support, either. The leak in the aft cabin turned out to be the split wire wrap bundle in the cockpit. port side. It runs from the pedastel aft and then down into the hull in that corner of the aft cabin. OUrs was assembled with the split on top, and water would collect in the bundle, and depending on heel, tack, and waves, flow into the cabin. We removed the false deck in the cockpit(a couple of screws) and caulked it-no more leak
