Mergatroid
Long window on starboard side caulk is getting old and has cracked, giving water an easy "in".I need to replace the caulk. QUESTIONS.....1. Are the windows secured by adhesive caulk? Or does the caulk just make it water tight?2. What kind of caulk to use.3. Any recommendations on problems or mistakes to avoid? 4. Advice on proper caulking technique. Thanks in advance.
