caulking around the windows
6
hunter 25.5 ossining ny
I would like to replace the caulking around my windows. What should I use?
Someone asked me what material the windows are made of?:)
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
And what did you tell them...?
Squidd
Sep 26, 2011
890
The frames actually... are they metal frames, plastic frames, or plexiglass glued right to the fiberglass..?
-na -NA Anywhere USA
I have found that lexan replaced into older Gray/Bomar plastic frames were glued in and I have used super glue for that. To fill in the area between the frame and lexan, I use an archeticuaral grade of 100% silicon that I have gotten from an Ace hardware over the years.
crazy dave condon
Sep 11, 2010
33
Hunter 23 Hudson
To secure the port lights, after i replaced them on my H23, i used butyl rubber, theyr sealed, neat, n dont require screw fasteners.
