Just read an interesting piece on anchor snubbers in the latest Practical Sailor. What really jumped out at me was not about snubbers but rather just how little load was required to lift the last link of chain off the bottom of the ocean and affect the anchor shank angle..
PS used a 100' section of 5/16" chain set to a 5:1 scope. To apply the load they used a chain hoist and measured it with a load cell. They physically pulled the chain to see how much load was required to lift the last link of chain eg: the anchor shank, off the bottom.
It took just 190 pounds to lift 100' of 5/16" chain at a 5:1 scope off the ground out of the water. The in water load calculation to do the same would be just 158 pounds to lift the last link off the bottom...
Seeing as I own a digital load cell and have physically measured the loads of our 36' sloop at 140 - 218 (218 was peak loads) pounds of load in 17-19 knots the idea of chain holding your anchor on the bottom is really considerably less than where I and many books and experts suggest it would be....?
I actually just ran the numbers through an anchor load calculator and it does not show the chain lifting until a load applied of 242 pounds yet based on the PS actual test data it takes just 158 pounds of load to do this... This means the wind conditions to affect anchor shank angle, with all chain, seem to be considerably lower than thought...
So if I am anchoring at 5:1 with 100' of 5/16" chain in approx 20' of water it will take just 17-20 knots, on our boat, based on actual measurements, to begin to lift the chain so the anchor shank angle is affected.
Interesting stuff to say the least....
Quote: Practical Sailor
"We fixed one end and then tensioned the chain with a come-along until the last links at the lower end had lifted free of the ground. Lifting this required a load of 190 pounds, which translates to 158 pounds in the water. Based on data from last year’s test (PS, May 2012), this would be the equivalent of about 15 knots of wind on a 40-foot boat anchored in about 15 feet of water with 100 feet of 5/16-inch chain."
We've all heard the old axiom that 5:1 on chain is okay but 7:1 on rode is needed.With this data it appears that this is simply untrue and that scope should be set irrespective of chain or rope/chain rode because chain alone really will not help shank angle when you really need it most........
