Catamaran Sailing
After 40 some odd years of sailing mono-hull boats yesterday was my first experience sailing a catamaran. The boat was a Hobie Getaway launched off the beach. The wind was 10 to 15 knots and there were three of us. My first impression was that it felt more stable than I had imagined. I guess I've not pursued sailing a beach catamaran because I haven't wanted to deal with a capsize and trying to right the boat. No worries yesterday. My second impression was that it was fun to sail. It took awhile to work it to windward but when the wind was in the 15ish area it seemed to go much better upwind. My third thought was that it didn't seem to be overly sensitive to sail trim. Maybe that's due to the greater apparent wind due to the greater speed over a monohull.
I wasn't comfortable sitting on the trampoline - I couldn't find a comfortable way to sit that didn't involve tucking my legs in. We didn't use the outboard seat (Rail?). But I'm reluctant to move around much due to balance issues I have. And I couldn't see a way to easily cross sides because of the mainsail which is boomless. And I kinda missed having the boom to grab for balance or helping to get to my feet from sitting. I can't see going around forward of the mast. I think you have to cross under the main basically on your belly. Next time I'll have knee pads to protect my very knobby knees kneeling on the trampoline.
The tiller is very long and during a tack problematic because you have to raise it vertically and try to pass it aft of the main. I was tempted to throw it backwards to drag in the water, steer thru the tack holding the bar and retrieve it after on the new tack - thoughts?
The first tacks were a problem because near shore the wind was light. Even with some boat speed it was a problem because I tried to turn too hard hoping to get the bow thru. I think I just stopped the boat. I guess I need to carve a turn and rely on the jib backwinding to bring the bow across. But I was surprised at how little momentum helped to bring the bow around.
When we furled the jib I brought the boat mostly into the wind and got stuck in irons. I tried to steer the boat going backwards as I would a monohull. It didn't work because the two hulls track pretty straight - like on rails. Next time I would furl the jib going off the wind shaded by the main.
There's more to learn but I'm looking forward to another session on the getaway.
I
Those small catamarans can be a lot of fun. They can be wet. A wetsuit or warm weather is advised. I always found that they tend to carve a turn - tack rather than a hard over-tack monohull style. No need to furl the jib. I found that easing the jib through irons and firming it up when the wind passes the bow made the tacks smooth and with speed.
The key takeaway from your experience - "My second impression was that it was fun to sail." :biggrin:
PEBI
Sep 30, 2026
68
Homebuilt 35 muck
Yeah in 2008 I saw just that in Sheerness (UK). Local sailing club. 8 cats. wet suits. 2 per cat. They were very shy. Doing circuits. Looked like hell of a lot of fun.
The SS Richard Montgomery, the famous unexploded WWII ammunition ship. Literally 10 min walk from where I observed the catmarans lol.
Sep 24, 2018
4,805
Catalina 30 MKIII Chicago
If you're ever in Tampa, I can highly the charter recommend Flip Flops sailing based out of Anna Maria Island. The guy has a 30ish foot Cat. VERY reasonably priced for small groups
dmax
Jul 29, 2018
1,361
Telstar 28 Buzzards Bay
Welcome to the dark side. Ted Turner, a rather accomplished sailor, said this after sailing a Hobie 18 for the first time:
"This is the most fun I’ve had in years. Why didn’t they have these boats when I was growing up? And it’s sure more fun than racing 12-meters, and all that other serious stuff."
When tacking a light catamaran, leave the jib cleated until the bow passes through the wind.
Throwing the tiller backwards (actually, you want to try to pivot it around back to the other side) is standard procedure when tacking - becomes second nature.
4,049
Corsair F-24 MK I Deale, MD
Tacking small cats.
Watch a video of cats racing. Olympics, or just good racers. The jib is NEVER backwinded through a tack. There is a better way. This applies to cruising cats as well.
  • Obtain best windward speed. Bear off ~ 5 degrees at most to build some speed, but don't bear off much. Prepare sheets for quick handling.
  • Pull the traveler very slightly above the centerline as you begin the turn (optional but helps with the turn on some boats).
  • Turn at proper speed. Too fast kills speed, too slow won't make it through. Practice.
  • Release jib when it breaks. No backwinding. Ease main sheet a little at head-to-wind (optional, but helps with acceleration out of tack and prevents the main from slowing the turn and forcing the bow up into irons).
  • Trim the jib the instant it will fill properly. No backwinding, but it should be trimmed at the first moment it will draw. This will pull the bow through. The main should be eased and the traveler down a little (depends on the boat and conditions). Very little grinding is required, because the jib will be trimmed in under no load as the turn is finishing, and will be fully sheet JUST as the wind hits it.
  • Continue the turn slightly past best course. Less in flat water, more in steep chop.
  • Bring the main in and steer up to true course as the boat accelerates. Do not rush it, but on flat water the over-turn will be very slight and the acceleration will be quick, since you did not lose that much speed.
I haven't backwinded a jib in decades, including my cruising cat, beach cats, and my current trimaran. All it does is slow the boat and prevent proper carving through the last half of the turn. But a good tack requires practice. The rate of turn and easing the main a little at head-to-wind can be key. This will keep it moving.
On beach cats, a little roll tack helps too. Don't head across until the boat is head to wind, then move it.
Backwinding is mostly for when you are doing something else wrong, or more probably, several things. All of the parts need to work together.
Shermandr:
  • Yes, you can toss the tiller extension into the water, but with practice the vertical pass becomes second nature.
  • You sort of slide across, or at most get on your knees. But mostly, you slide. I never touched the boom. (sailed beach cats for years, and a Prindle 19 last summer).
  • There should be hiking straps to tuck your feet under, like a dinghy (with or without seats). Add them if missing. Even if you are not hiking out, the most stable position is with your butt just over the edge, so you don't slide downhill when it heels.
  • Sailing a cat with main only (exceptions for some very high performance mono-rigged cats with dagger boards) you do NOT center the traveler. Leave it down at least a foot, and make sure it is eased for the tack. Otherwise it will push you into irons. Without the balance of the jib, and the jib to turn the wind around the main, correct main trim is well eased, even to weather. Traveler center is ONLY for when there is a jib. Also, remember that furling the jib changes the sail balance point. Having the main in tight will increase weather helm and the boat will be slower.
  • Helpful
dmax
Jul 29, 2018
1,361
I agree, I only rarely backwinded the jib on my Hobies but it is available when having trouble, especially in high winds.
Well those responses are a bit of an eye opener. Thanks for posting. I am looking forward to my next sortie to practice and see if I can do better.
I watched several videos are righting a capsized Getaway. I don't want to do that.
dmax
Jul 29, 2018
1,361
On a nice day you should try capsizing (athwartship) and righting so you know the limits and how to avoid it and also know how to get going again. Pitch-poling is what you really want to avoid. Don't know about the Getaways, but righting a Hobie 16 is pretty easy with the righting line in place. I turtled it once (pitch-pole in 30+ knot winds) and even got it back upright.
  • Helpful
The righting line is underneath the trampoline? I saw that in a video. It attached to the inner hull in two places (Bow and aft) forming a loop. The crew then pulled on it from in the water to right the hull. The video wasn’t clear about what the crew did to brace themself so that pulling on that line didn’t just pull them closer to the capsized hull. There was also a video using a pole to right the hull. Since our boat didn’t have a pole that option appears to be unavailable. I didn’t look to see if there is a righting line rigged.
dmax
Jul 29, 2018
1,361
You stand on the inner part of the hull that's in the water, grab the line and lean back, pushing the hull downward with your legs. It's mostly your weight that does the work - using two people helps.
  • Helpful
4,049
The orientation of the boat vs. wind makes a difference when righting.
  • If the boat is righted immediately, you will be fighting the same wind that blew it over.
  • If you let the boat pinwheel until bow-to-wind, the effect is neutral.
  • If you wait until the mast is pointed into the wind, it will come up easier ... and may instantly blow right on over again (hold on to the beam and pull down as it comes up).
Also, check that the mast is well-sealed against filling with water. The smallest leak can allow gallons to leak into the masthead while you wait, making righting very difficult or impossible.
Sticking the mast into the mud in shallow water is also fun. I haven't done it, but again, it can make righting impossible until you rotate the mast out.
colemj
Jul 13, 2004
1,175
Which goes well with the fact that flipping a Hobie 16 is even easier. I think that boat was designed to pitchpole at least once an hour. Keeping the leeward bow above the water on that boat is a real challenge. What a fun boat for youth.
Mark
dLj
Mar 23, 2017
5,255
Clearly too many words in that sentence, should be: What a fun boat!
Reminds me of an old saying: You don't stop playing when you get old. You get old when you stop playing!
dj
Likes: Michael Davis
Gulp! Pitchpole?
I guess that’s pic show crew sitting on the aft of the windward hull.
colemj
Jul 13, 2004
1,175
dj
While that sounds aspirational, I no longer can bend without breaking enough to be slingshot off a trapeze from the rear of the boat, over a 15' high arc, and slammed down into the water in front of the boat.
I'm also wiser now and have moved on to wing foiling and other things that keep me closer to the water...
Mark
Likes: dmax
colemj
Jul 13, 2004
1,175
Gulp! Pitchpole?
I don't see a pic, but the Getaway is an entirely different boat in this respect. Much more civilized.
I misspoke earlier, and was describing my experience with the Hobie 14, not 16. The Hobie 14 was particularly prone to pitchpoling among the Hobie line. Something about the hull design and bow volume that caused the bow to just sink into the water at high speed no matter how far back and out on a trapeze one was. It's like a hole just forms in the water and the boat tips into it. And all steering and sail control is lost the minute it happens, so no coming back.
It was a lot of fun.
Mark
dmax
Jul 29, 2018
1,361
Yeah, I was never really impressed with the Hobie14, good for a small lake. I only pitchpoled a 16 once and we were really pushing it. Just don't let that leeward bow start submarining.
Ah gee guys. @shemandr just broke out on his own trying a new experience. He is having fun. Discovering new sailing opportunities. Then you go and talk about pitch polling and being launched 15 feet, flying through the air. :yikes:
Give the guy a chance. :biggrin:
  • Ha
Likes: JamesG161
colemj
Jul 13, 2004
1,175
While it might not sound like it, I was remembering those incidents as some of the most fun sailing I've had.
The Getaway is an entirely different boat, and much more civilized. I'd enjoy sailing one now.
Mark
