Catalina Traveler
704
Catalina 30 Sidney B.C.
I have a 1982 Catalina 30 with a curved traveler over the cabin and like the look of it and would like to keep it curved but would also like to upgrade to a line controlled system , does any one have any ideas as to what could be added to the existing track
May 23, 2004
3,319
Most Catalina 30 owners with the older traveler setup change it out for a straight system. You can probably get a look at the setup on www.catalinadirect.com You can also try the Catalina Owners Association.
Sep 29, 2008
1,978
Catalina 310 #185 Quantico
Post a picture. I am certain you could modify the traveler. It was most likely made by Garhauer, and you can contact them on their website about mods; they will be pretty reasonable and a lot cheaper than a new traveler.
Joe
Jun 1, 2004
8,323
The Garhauer equipment didn't start appearing on the C30 until the Mark II version in 1986, replacing the old Seaward and Nico stuff, including the curved traveller.
http://www.catalina30.com/C30Yacht/C30Yacht.htm
I know you may like the look of the curved traveller, but there was a reason it was discontinued...... they perform poorly..... by pullling the boom down when shifted to the outboard position the mainsail twist is changed, defeating the whole purpose of having a separate traveller and mainsheet...
Garhauer will hook you up with a dandy, modern system, they are an excellent company......... www.garhauermarine.com but if you're absolutely jonesing to reproduce the curved track, you might give Catalina Yachts (i.e. the factory) a call to see if they have any in their parts inventory..... remember...this boat manufacturer is still in business and is widely known for their ongoing service to all Catalina owners no matter what the boat's age. www.catalinayachts.com
