Catalina Smile
When I purchased my 1978 Catalina 30 in 1987, it had the 'smile'. The folks at the yard suggested that I dig out any loose stuff with a beer can opener, let it dry, fill it with Bondo, smooth it, and apply bottom paint. They said that I could expect this to be an annual chore because sailing would cause just enough flexing to break the seal and permit some of the Bondo to wash out.Sure enough, when the boat was hauled at the end of the season, the smile was back. I never bothered to fill it again. During the ensuing years, it remained, with no changes. It was still there, same as before, when the boat was hauled a month ago for a pre-sale survey.The surveyor explained to the buyer that it was a cosmetic situation and compared it to the filletting of automobile panels after they are assembled. The fiberglass hull molding and the lead keel molding being individually formed, and of dissimilar materials will never achieve a precise face to face fit. They are bolted together with a layer of a sealant compound to prevent the intrusion of water through the bolt holes. Any separation at the edges of the joint is filled, smoothed, and painted.Nothing structural involved, just cosmetics.The key, he said, was to ensure that water was not entering the bilge through the bolt holes. His suggestion was, with the boat afloat, if you suspect a leak at a keelbolt, empty the bilge and towel it dry. If there is a leak, you'll see it immediately. If there is no leakage, there is no problem. If your friend is handy, perhaps he can find a waterproof filler that is somewhat flexible and may stay put.I'm sure he could find a better use for the $1,500.
