A friend of mine, today gave me a 3" X2.5" X 8' piece of aluminum tube. Very light and very strong. I will make my mast stepper from that and use the design form above with 3 or maybe 4 pintles this way I can raise it even higher and there is enough room for it to hang lower for towing. I will for sure take pics and post here. I would have bought the CD mast up if it weren't for all my other projects and toys. Have to split the money up
Just be careful in your quest to have it high that you pay attention to how LOW the bottom is. You DON'T want it to ever drag the pavement (obviously). Mine, for instance, could never be higher in its
highest position unless it was also higher in its
lowest position, if that makes any sense. Based on the mast being level while trailering, it could never be raised higher than it can be now, regardless of the number of pintles.
It took me three prototypes to figure this out.
James- Here are a couple pics which will do better than words to show how mine is laid out. Yours or anyone else's will vary a little based on how high the boat sits on the trailer.
The stubby little cross member keeps the crutch from rotating and digging its pintles into the transom (if you didn't already figure that out).
BTW - DO NOT use aluminum angle to make your pintles! This is what very quickly happened to my first prototype, which used aluminum angle:
