Catalina Cushions
Jul 5, 2004
11
-catalina C 22- Eugene, Oregon
Does anyone have a diagram or photo showing all the cushions in a 1988 C22? I have a few missing and am trying to get them made.
Thanks
Bruce Ebling
Aug 3, 2012
2,542
I would imagine you could decide where you want cushions, cut a brown paper pattern, and have to cushions made to fit. I think it is up to you! You can't be wrong if it is the way you want it!
Thanks,
Andrew
Jan 13, 2013
214
Catalina 22 Lake Champlain
We put a foam "topper" on an old bed we once had. Firm, but not overly so.
I was in Costco earlier today and noticed some really good prices on what they're calling a "gel-foam topper." Good, as in half the cost of 3" thick foam.
I was thinking of using the 3" stuff (also known as memory foam) instead of the foam for any furniture app - and chopping up a queen or king size "topper," after drawing a pattern - and seeing how the finished dimensions would be with no - or minimal - seams?
I wonder if "topper" memory foam is open or closed cell? I wonder, given the cover you make would be the first line of water-proofing, not the foam itslef - if that really makes any difference?
Anybody here crazy enough to think like I am ???
Nov 19, 2008
2,129
Catalina C-22 MK-II Parrish, FL
Ken,
I purchased the queen size 3" memory foam topper from Costco a couple months ago. I plan on either installing the memory foam in my cushion covers,(existing cushions have 3" foam), or I also thought about having new cushions made with 2" foam on the bottom, and 3" memory foam on top. We have a MK-II so I'm only having to do the two quarter berth cushions where we sleep. I know my wife sleeps much better and has less ackes when we use a 1" memory foam topper, so my thinking is that 3" of memory foam will have to be close to heaven to sleep on for her.
One of those winter projects I need to do.
Don
Aug 3, 2012
2,542
My wife purchased generic cushions online for 1/4 the price of ready-made cockpit cushions. They are made of the same Weatherproof fabric as others. She bought them slightly larger than the cockpit seats. She simply cut and resewed the cusions to fit. I imagine there are many low-cost solutions out there.
Thanks,
Andrew
Oct 17, 2011
2,809
Ericson 29 Southport..
Thoughts of this nature is about your onliest option. I thought earlier about the question, and the dimensions of every cover in the boat would be a helluva lot of numbers. There are a few cushions that are symmetrical around the table, but the others are all tapered. Some more, some less. Without an old cushion, a pattern is about the only recourse.
Jul 23, 2013
487
1981 Catalina 22 #10330 Bayview, ID
Bruce,
I don't know how different an '81 is, but I'm at the beginning of sewing a complete set of cushion covers and would be happy to share my dimensions if they would help.
Nov 18, 2012
183
Catalina 77 - 22 / 75 - 30 Lake Arthur, LA
I sure would like those dimensions. I have a '77 with no cushions.
Dec 23, 2008
772
Catalina 22 Central Penna.
Make a pattern
Making a pattern is always the best way to go. Even using an old cushion and trying to get measurements the new cushions may not fit. As material and foam ages is shrinks and twists making the new cushion fit like the old one. With a new pattern that matches the space the new cushions fit perfectly.
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
Thanks
Bruce Ebling
Which cushions are missing?
I can photo mine and try to measure those.
Dec 5, 2011
558
Catalina Catalina 22 13632 Phenix City
I have an '86 and am currently re covering some of them and could give you the measurements of the foam.
Jul 23, 2013
487
Attached is a PDF file of the overall dimensions of the cushions in our C-22. There are a few fine points to watch out for. Only the seat back cushions are strictly rectangular. All of the other cushions have one or more tapered sides to fit the hull curvature. Also, the curved cuts of the V berth cushions are also tapered vertically to fit the hull taper. Otherwise, you will get a gap there. So use these dimensions for estimating purposes and if you don't have some of the cushions already, make an accurate pattern for the best fit. These dimensions could also be +/- a half inch here or there from the original design due to the factory cuts of the foam, which wander a little bit.
Another issue to consider is the table top cushion. The stock cushion's inboard edge aligns with the forward seat cushion edge. I'm cutting ours several inches longer to completely cover the table top and to align with the aft seat cushion corner and the inboard edge of the keel trunk. This makes it fit together better with the other cushions to make a full-width bed in the settee area. Along with that, I'm making an 11th cushion to cover the step and finish the "puzzle."
I hope this helps somebody. If you need more information, PM me and I'll do what I can to help.
Enjoy!
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
The first post owner's '88 is a New Style. Some of the cushions are different from the older style boats.
Sep 30, 2013
3,616
I hope this isn't off topic, but for those who have had their cushions recovered professionally, do mind if I ask how much it ran you?
Jul 5, 2004
11
Cost to recover cushions
We had a local upholstery lady do the work. It ran is about $500 for labor. She did an amazing job!
Bruce
Aug 7, 2025
12
Catalina 22 Boston area
Enjoy!
Thank you for this diagram!
Aug 7, 2025
12
From catalina downloads in Catlina owners org.
Thank you! Looks like the Stingy Sailor one in the original post. Is this from SailboatOwners.com or from catalina22.org or somewhere else? I didn't see it in those locations.
Also, any thing similar for the wooden hatch covers in the cabin? I have one mysteriously ill-fitting one in the middle of the v-berth (rectangularish, with a metal finger handle in the center -- an inch or so small on sides; just barely stays in), and wondering if a diagram can help me find some other mistake I've made.
Thanks!
