Bob
Bob: I agree with you that it is nice to have someone to talk to, even if the same question is being asked that was already discussed many many times. At least it lets us know that people are interested in their C-22s and in taking good care of them. I have received some great advice from this forum, and it has made me feel more comfortable on some of the little boat projects that I have undertaken. My hull number is 9285. It’s a 1980 that we actually purchased in late 1979. I have never taken my turning ball out. I have purchased a replacement one, but when I replaced the cable, I checked the movement of the cable, and it was fine so I figured that it was OK. I did this by having the boat suspended by slings inside a truck garage. I could easily lower and raise the keel all the way, so I figured that I didn’t have a problem. I do this every year when I paint hull and the keel. I DO know that it is possible to put the cable on the wrong side of the turning ball, and that it must go through the groove on the stern side of the turning ball. It is because of this fact that I can say that I am rather sure that my C-22 DOES have a turning ball. (The first time I ever realized that there even was a turning ball for the cable was the first time I paged through a Catalina Direct catalog, at a Catalina 22 fleet picnic. I was surprised to see this myself.) I don’t understand why your boat doesn’t have a turning ball, or isn't cross drilled for one.I’m in my shop writing this message, so I just looked for the extra turning ball that I mentioned above, and after about an hour, I found it. I attached a photo. It is about 1 1/4 inch in diameter, and the hole through it is slightly bigger than 1/4 inch, ~.261. I think that you should call Catalina Direct and ask them what you should do. This time of year, or after Christmas, they will probably have plenty of time to talk to you. (I called them last spring, and they were busy at that time). I think that’s part of what you pay them for when you purchase something there.Relative to your last question about the SS Ball valve, I replaced the seacock to the cockpit drains last year, and that pipe looked like new. Our boat has been in brackish water for at least 15 summers of it’s 24 years. (I replaced the brass or bronze valve that came with the boat with a plastic ball valve last spring). My only concern about the SS one that you used might be Galvanic corrosion of the brass pipe that goes through the hull. Galvanic corrosion is, of course, caused by dissimilar metals, but I don’t think that brass and stainless steel are too far apart on the Galvanic series, so I’m not too worried about a problem. I’m sorry I don’t have exactly the answers that I think you were looking for, but maybe someone else reading this will. Aldo
