I like having a backstay. How do you bend the mast without a backstay with an adjuster?
Ah. GREAT question. Someone is paying attention!
First of all there are two answers.
For boats with standard mainsails (Hunter B&R rigged) you don't get to bend the mast, and that a bad thing. You've lost a key way to shape the sail. I'm not interested (or going to talk much) about that.
But on to boats with SQUARE TOP mains. These boats cannot have fixed backstays because the sail would not clear them on a tack or gybe. So how do you bent the mast?
Answer? You don't! And that's all good!
I know that sounds strange coming from a fractional rig tuning freak, but there is something else at play. Its part of the shape of the sail. On a traditional triangle mainsail, the leech is supported sailcloth; ie it is under tension from the mainsheet. As is the rest of the sail. To get it to twist off or flatten you have to be very active with sail shape and position controls.
On a square top, all of the sailcloth outside the line drawn from the clew to the head is unsupported, and will twist off with excess pressure. That why these sails are ALWAYS full batten. The auto-twist means that as pressure comes up in the top of the sail, the sail reacts automatically and twists off. Ill see if I can find a pic taken up the leech; its an amazing thing. So you typically sail watching not the top but one telltale down while trimming, and let the sail do its thing.
Someday most sailboats will be like this. Its already happening.
