I broke my starboard beam stanchion on a hard jibe with a preventer attached. The center 1/2" threaded stud broke off at the base of the stanchion where it is mounted on the toe rail. The problem is I can't find any way to get to the 3/4" nut that is tight on the remaining stud below deck. Because it is so long it is jamed against some wood support behind the teak strip and fiberglass molding above the shelf. It appears the stud is way to long and must have been installed before the deck was stepped to the hull.
Has anyone ever replaced this stanchion?
Thanks,
Randy "The Reach" #837. Cat 320
Thanks,
