Catalina 310 Mattress Replacement
Catalina 310 77 Atlantic Highlands NJ NJ
Has anyone replaced the original forward berth mattress on a 310? If you didn't buy the same kind, what did you replace it with?
Thanks
Jack
Nov 16, 2012
1,055
Thanks
Jack
I talked to Catalina Yachts and got a quote for a replacement. Not cheap. Decided to stick with the existing one.
Likes: Alansails
Deleted member 117556
We looked into this quite a bit and there was no reasonable solution for a replacement mattress. So we finally tried a Lucid 2" gel infused memory foam topper that cost $60-70 (queen size). We cut it with scissors and it is perfect. Solved our problem and we even bought a 3" version for our bed at home and love that too. Highly recommended.
JRT
Feb 14, 2017
2,060
Since we are on mattress ideas, my wife asked about sheets and what to buy, any recommendations?
Oct 3, 2011
835
We started out with just Queen size sheets, this year she has purchased the Fitted sheets but we have not tried them out.
Curt Sawyer also has fitted sheets he may chime in!
leo310
Dec 15, 2006
649
Catalina 310 44 Campbell River BC
For us we gave the mattress to a Mattress maker in town as a template as for the sheets we us queen size with tarp holders and buggees too hold it in place.
Likes: Alansails
Nov 16, 2012
1,055
I took measurements and sewed a set of sheets to fit, including a comforter . Worked great, very comfortable. I could probably find the measurements, if anyone’s interested.
Likes: Alansails
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
We just replaced our mattress this weekend. We ordered a latex queen mattress from the Foam Factory. It's about 6 inches thick. We put the old mattress on top, traced out the rough shape. Then cut it with an electric carving knife. The cuts weren't pretty but you put it in a zipped cover so it wasn't noticable.
The original mattress is tapered to follow the hull. We didn't do this so we can flip the matress.
We had a 1.5 inch memory foam topper, so we kept that as well. It was great. Slept very well last night.
Likes: Tom J and JRT
Dec 5, 2010
84
Beneteau 343 274 Niceville FL
Thanks
Jack
We took the old one to a local mattress factory and they used it as a template to make us a really nice replacement... Fox Matress in Holly Hill FL. We are very happy with our memory foam mattress in the house so we may go that route if we ever need to change the boat mattress again.
Good luck
Nov 18, 2010
2,441
Good luck
Just do some research on memory foam vs. latex foam. Down here in the Caribbean most avoid memory foam. It's heat activated and reflects much more heat.
Dec 16, 2011
260
Catalina 310 Atlantic Highlands
Originally I was just using King Sheets from Target for both berths, but they were cheap and my wife and kids hated them and never wanted to sleep on the boat because of the poor quality. So I bit the bullet and ordered them from Catalina. They were quite expensive, but the family loves them. I think now you can get them for less from Catalina Direct. I'm not sure that was an option when I got mine 4 or so years ago.
