Catalina 30 TRBS: 155 vs. 135 genoa
Bob Moretti
Don, Your posting on the various genoa sizes you've used on your boat got me thinking about mine. The 155 genoa on my tall rig is a bit much unless the true wind speed is less than about 13 knots. The local sailmaker, who owned a Catalina 30, tried to talk me into a 135, but another major sailmaker reminded me that the average wind speed on Lake Michigan is about 8 knots (but with tremendous variability and range). So, I bought the 155, but still think about a 135. Sounds like you've been there. If I remember, correctly, your C30 is a standard rig, right? Logic is beginning to tell me that a 135 might make the best sense for a tall rig C30.
Other Catalina 30 Tucson, AZ
135
Bob: I think the 135 low cut (not a deck sweeper) is a great all around sail for a cruiser. My problem with the 155 was that for me personally it was just too much work for single handing. Additionally, I have gone head to head with a C30 (standard rig like mine) friend of mine who has a 155 and he has yet to beat me. He is a middle to back of the pack racer. I know my sail trim is better than his and that is the difference - for now. When he gets better with his sail trim I might have a problem. He may get me but it won't be by a lot. I Think a 135 on a tall rig is probably like a 140 on a standard. I'm not a sail maker expert and just pull that out of my rear end but it sounds logical. In other words, I think going head to head you'd edge me out. The 135 I have just cleared the safety lines so I did not have to deal with skirting.
Bob Moretti
Definite advantages
Don, Your head-to-head comparison with your friend who has a 155 is interesting, even though you also cite differences in sail-trimming ability. The sailmaker who tried to talk me into a 135 regularly raced on Lake Michigan (my location) using a 135, and did quite well. In fact, he won a National Championship using that sail. He used a short pennant at the tack to raise the sail off the deck a bit. I do a lot of singlehanding myself, and the 155 definitely is a lot of work. Just the skirting issue itself is annoying. And in anything other than light winds, cranking the sail in takes a great deal of effort (Lewmar 40ST winches). I do have roller furling, so I can at least roll the sail up a bit when desired. With the foam luff, shape still is reasonably good.
Rick D
Jun 14, 2008
7,182
Overlap
Notwithstanding the fractionally-rigged racers who run 155's on things like Santana 35's, my sailmaker recommended nothing more than a 135 for my fractionally-rigged 40.5. He said there is little additional drive offered and that you give up much of that with trim issues. I did go to a near deck-sweeper (clew about 18" up) which gives some real drive when close hauled at the expense of visibility and the need to skirt the jib sometimes. I did have a 150 made for my masthead O'Day 27 which made a big difference in light air but was a handfull once it piped up. Having said that, in both cases I'm comparing old factory sails with new custom loft sails, so it's hardly a fair comparison. RD
Jun 4, 2004
844
Hunter 28.5 Tolchester, MD
Why not Both?
On our 1986 masthead B&R rigged Hunter 28.5 we regularly use the 135% or the 155% either with the Admiral as crew or when singlehanding. Since neither is on a furler it is prudent to be aware of changing conditions, but its never really been a problem to drop either headsail to the deck, head to wind with the wheel brake locked. I don't feel undergunned with a 135 when the wind is in the teens but I wouldn't hesitate to change down from the 155 to the 135 or just reef the main if I were ovwerpowered on an upwind leg of a race. Day sailing or cruising, I'd just change direction to a more comfortable point of sail. Conditions on the Chesapeake are somewhat predictable and light air can be the dominant sumertime condition often enough that I wouldn't want to be limited to a 135 and end up motoring all the time.
