Roger K
We have taken our 1989 Catalina 30 out into the Blue Pacific for the first time ever. In the process of sailing it up the Washington Coast with the rail in the water, rust stains have started to show on the white hull glass around the stansions, bow pulpit and rear rail. A sailing friend said that stainless steel isn't stainless! does anyone know if during the late 80s if some inferior type of steel was used for the rails or maybe it is the bolts that would explain the rusting? This boat has always been in fresh water, but I don't see to many other boats with the rust from a similar condition. I don't see rust at any of the welds or on the stainless steel it's self. So does anyone have a good idea where this could be coming from or causing it. PS I understand "oxalic" sp. acid will remove the rust from fiberglass but I would like to figure out a solution rather then having to remove the rust every so often and then wax the hull again.
