Hi I have a 1985 C30 mk 1 and my fuel tank sender went bad. I found a new reed style sender on Catalina direct and some new replacement tanks shaped like mine but not the same dimensions. I think they may have put tanks in different locations. Mine is centered under stairs under inspection board very easy to access. I have an 18 gallon tank and it is 21"wide 18" long and the depth at the deep end is 12" and the shallow end 8". This is very different from the tanks they offer from cat.dir. Their new tank is 21"x27" and 10" deep at the deep end 4.75" deep at the shallow end. My tank is shorter and deeper but about the same capacity. I bought the new style sender and it is 8" long so it is way too short for my tank.
Also if I were to buy the new tank the slope of the new one is 2" greater than mine so it wouldn't sit level on the original bed.
Can anyone relate to this problem? Does anyone have an original tank with the same dimensions as mine? If so, if you replaced it with C. dir. tank did it fit OK?
