Ray, Thanks, more questions follow:
Ray, I am not familar with how I should reply to your response, having not used this type forum in the past...I'll try this and hope you notice...Fist of all, Thanks very much for your response...I have heard the power of the Atomic 11 was questionable...I will be sailing on a lake in Arkansas...do you believe the engine will be okay in this type of situation rather than a coastal setting or open seas...the boat has all new electronics...it does have roller furling but needs new sails the bottom has been well taken care of and new bottom job completed this summer...the sides have also been waxed and well kept...the engine has been regularly maintaiend and the boat has had the same owner since 1984...they are asking $30,000...I consider this too much but am not familar enough with this particular model to know what it is worth...I have seen 1981 to 1983 models on the Internet from $17,500 to $23,000, the 1981 with the Atomic 4 gas engine...The boat has not been sailed in salt water, fresh water only...any suggestions or comments would be greatly appreciated...Thanks.
