Catalina 270 Portlight
5
- - Michigan
Anyone know the manufacturer/model of the forward portlights on a 1994 Cat 270. I called, Catalina, Catalina Direct and Lewmar. No help. I think they might be Bomar 5000 series. Can anyone help me out? I want to replace the gaskets. Thanks
Catalina 320 Dana Point
Also have a '94 and was hoping that the
gaskets Catalina Direct had recently added were the right ones for those ports. I've attached website here.
Jul 7, 2005
5
- - Michigan
Bomar
Ted, Since you have a 94 Cat 270, please take a look at the attached link to the Bomar 5000 series and compare picture to yours. I looked at the Lemars gasket from Catalina Direct but I don't the rotating "key lock" latches. Mine snap shut from the bottom. Let me know what you think.
From appearances, mine look more like the
2000 series, mine have two hinges & dogs not 3 as in the picture but otherwise hardware is identical. Dogs are black plastic that rotate 90 degrees to lock, starting to suspect that our boats might have different lights even tho built at about same time.
