Catalina 27 working jib
2
- - Duxbury
Does anyone know the measurements for a catalina 27 standard rig working jib (100%0. The luff, foot, leach and LP. Thanks
David
working jib
I think your Luff is 31.50,Foot 13.58 and leach is 29.20
Joe
Jun 1, 2004
8,342
sail dimensions
go to this link and search the big box for catalina 27.... headsails http://thesailwarehouse.com/cgi-bin/web_store.cgi?page=storeframe.html&cart_id=
David
working jib
Evening Wind, I dunno what year your 27 is,what I told you is what my owners manual(84) shows. Here's the info out of the book word for word. Standard Rig Plan *main *Dimensions Luff 28.66 ft. J 11.25 ft. Foot 10.50 I 34.00 Leach 30.50 P 28.66 E 10.50 *Jib Luff 31.50 ft. Foot 13.58 Leach 29.20 150% Genoa Luff 34.50 ft. Foot 17.875 Leach 33.375 *Spinnaker Luff 34.00 ft Max Girth 29.25
David
working jib
Forgot to say,the book does not show a LP for 100%. just 110% and 150% If you need it,I can fax you a copy of the page.
Joe
Jun 1, 2004
8,342
LP is related to J.....
100% jib ... LP equals J or 11.25 for all Catalina 27's. In the sail's triangle the luff is the base, the LP is the height. The LP and Luff determine the sail's size. The size is expressed by relating the J and the LP in the form of a percentage. The leech and foot dimensions, however, depend on the clew's height above deck. The height of the clew is controlled by the LP's position on the Luff. Whereas the luff and LP of a given size sail will remain constant. Its leech and foot lengths can vary but their sum total stays the same. What does this mean? It means sails of the same size can have very different shapes that offer different performance features. So determine where you want the clew, then draw it out on graph paper to come up with the foot and leech dimensions. Remember the boat's foretriangle is a right triangle with the luff as the hypoteneuse, the J and I are the legs. On the C27 standard the Luff(forestay) is 34.5. J (foredeck length) is 11.25 and I (mast, or jib hoist) is 34. Plot out various clew locations by moving the LP up and down the Luff and compare the foot and leech dimensions. Make sense?
