Catalina 27...what outboards will fit in the well?
Bob Shafer
I just bought a '75 Catalina 27. It came with a very old Mercvury 9.9 which is just about to die. What two stroke motors will fit in the well and tilt up easily? I think the Evinrude/Johnson 9.9 before '92 will fit, but the newer ones are bigger and might not. Help1!!!!
E
Echo Gulf
Yamaha 9.9 4-stroke
I've just replaced our Mariner 9.9 2-stroke with a Yamaha 9.9 4-stroke High Thrust. It's a tight fit and requires some minor modifications, but it works well. In fact, I'm of the opinion this motor is ideally suited to Cat 27's. Enough power to handle almost any situation with very conservative fuel consumption. To get the motor to fit I cut about 1/2 inch off of the 3/4 inch lip on the back of the lazerette hatch over the motor opening. Also, the motor cowling has a handle set into it at the top back. To clear the top of the opening for tilting the motor, this handle must be removed. This is accomplished by simply removing the four bolts in the inside of the cowling. Under this handle you'll find a small opening (vent) I fashioned a plastic cover that kept the rain out but still permitted the motor to breath through it. Space limitations and the additional weight of a 4-stroke made it next to impossible to raise the motor and lock it into place with the built in locking device. This was easily overcome by fastening a old boomvang onto the top of the motor cowling and to the lazerette bulkhead, the mechanical advantage permits even junior crew members to raise the motor and by using the built-in camcleat locking and unlocking is simple. Both Cat 27 owners, in our small marina, are using this motor, we both strongly recommend it. Best of luck to you, Echo Gulf sv SeaRaven
H
Harry
Johnson 8 Sailmaster
Fits easily in the well and tilts without banging nuckles. Obviously slower than a 9.9, but it pushes the boat at 5.5 to 6 knots with no problem.
A
Andrew
Nissan 9.8
The Nissan 9.8 version NS9.8BEP2 has the 20" shaft, electric start, remote control, generator and the 7.5 prop for larger boats. The motor FITS nicely and tilting it out of the water is no problem. You could even get a little vector thrust from turning the motor. Best of all, no modifications required.
mike walling
motor
I have a yamaha 8 horse. Its about 5 years old and it barely fits. I can pull it up with my right hand but my wedding ring gets jammed against the top edge when I try to use my left. Tight. The 8 horse has been plenty powerful. With a clean bottom it pushes the boat at hull speed easily. I am sure I could find a time when it would be underpowered. The Yamaha uses a 100:1 oil mix so I like to think I am putting a little less oil into the water.
