Blair Bugher
Am looking at a 1986 Catalina 27. There is evidence of moisture in the cabin bulkhead where the shroud/spreader chainplates fasten. A moisture meter gives a "saturated" reading on the exterior deck adjacent to this chainplate. Is the chainplate a strainght bar, bolted to the bulkhead in the cabin (which is what I see), or, does the chainplate have a "T" welded to the vertical bar and embedded in the deck, to spread the load to the deck as well as the bulkhead below? Reason for asking is that a horizontal reinforcement in the deck would cause a moisture meter to falsely read "high", and no reinforcement means the deck is likely wet.Thanks
