Catalina 27 pump out system
2
Catilina 27 Berkley
I have a Catilina 27 - (1985) I cant find the pump out "valve" - not on deck as show in scimatic that I have , could it be in the anchor locker on the bow? I followed a 2 plus inch from the holding tank to the anchor locker- has a hatch( threaded) . I just bought this boat and am trying to figure out the plumbing system. Please call if you can 707-206-8302 or E Mail -larry.conover@sbcglobal.net
Jul 28, 2009
38
Catalina 27 Lake George NY
The pump-out fitting for the holding tank is located in the bottom of the anchor locker in my 87' Catalina 27. It is a roughly 3 inch diameter black plastic cap labeled waste. The cap has an eight pointed star shaped hole which accepts a winch handle. The winch handle is used to unscrew the cap.
Apr 5, 2010
565
Catalina 27- 1984 Grapevine
My 84 model has it at the bottom of the anchor locker, don't ask me why. It is under all the anchor rope. Seems like a bad idea, I only found it on one of the rare days I had the anchor out and went up to the locker to clean it out. Being covered with wet rope doesn't seem like a good way to vent. I'm guessing you have same set up.
