Things to look for
Sails are important, but you can always find used sails (I found my "new" main here). I also have a 73 & did my own survey. I read up on what to look for - go to your library & check out a couple surveying books, they're invaluable.Check the keel bolts. Some rust shouldn't be a problem (expect it in this old of a boat) but if they're completely unrecognizable as bolts, be wary. Outboard motor, I'm assuming? That's a lot easier to do your own survey on cuz it's not so integral. The sailtrack on the toerails are notorious for leaking and are a complete b*&#@ to remove & rebed - mine leaks (the only leak on the boat) a little but I'd rather live with that tiny bit of water than deal with those impossible fittings! You might want to check the bulkheads where the chainplates are connected. If there were any leaks in the past, it could have softened the "wood" and made it spongy, which could be a potential problem. Walk all over the deck to check for soft spots indicating delamination. Check the thru hulls for any corrosion. Bilge pump? That's all I can think of off the top of my head. Have fun - she's a super fun boat!LaDonna
