Try This
I owned a 1988 C27 and did replace the holding tank. Yes, it does appear the tank is "glassed" in but actually it is possible to remove without to much work at all.On my 1988 C27, under the V birth cushions there are wood access panels. Simply remove these wood panel. This will provide access to the tank. There is a piece of plywood in front of the tank that is held in place with a strip of fiberglass, looks like white tape, on the port and starboeard side of the tank running top to bottom. With a very sharp box knife cut the fiberglass strips from top to bottom. Now simply "push" the plywood piece forward from the top. The pylwood is also held in place at the bottom but it will push forward like it is hinged. Two people maybe required, it's tough!!Remove the tank......assuming plumbing has been removed first...If replacing the tank, postion the new tank (avail from Catalina) and attach the plywood back with a "L" bracket on both sided to place the fiberglass that once held the tank.Good Luck....
