Refurbishing the keel on my 78 C25. I dropped the keel using the 4 threaded rod technique. With the keel out of the way with the rods still screwed in the weldments I noticed they all could be wobbled back and forth / side to side. It seemed to me the weldment threaded holes were stretched out a bit bigger at the bottoms allowing the rods to move. The rods were screwed in as far as possible by hand and felt firm. There were also screws screwed in next to each weldment that appear to be pressing against them. I asked on the C25 owners forum about this but no one knew. I found this pic searching google images. This is what mine look like except paint color. by you can see the slot head screws by each weldment.
What are these screws for? Any advice on changing out the weldments or not. (its a big job). or should i just use blue lock tight, or red, or epoxy the bolts in permanently putting off replacing weldments for a couple of years.
thanks James
thanks James
