Catalina 22 Wing Keel Lift Points
Jun 17, 2017
26
Com-Pac Eclipse Pensacola, FL
I recently bought a 94 Catalina 22 that is in dire need of bottom paint. I took it to the local shipyard to have it done. They have a huge 100 ton crane and asked me where to put the lifting straps. I had no idea so I told them to do their best. The did and it seems to have all worked out as the bottom is being painted this week. I am just wondering, has Catalina identified somewhere on the deck as to where the lifting straps should be placed?
Generally the lift points are at the strongest part of the boat, which is where the bulkheads are. So, on a C22 the lift points are likely at the aft end of the cabin and just in front of the mast step.
On larger boats, clearing the prop shaft and through hulls is a concern.
Likes: rgranger
