Repacking winches
Hi Gill!There are lots of good books to buy or check out from the library regarding general boat maintenance, all of which should include repacking winches. This should be done (in an ideal world) yearly but every couple years (depending on environmental considerations) should suffice. Now, I'm not sure about your "specific" winches but I'm guessing they're not self tailers (duh!). This saves a step. You'll have to determine how to remove the drum but from the age of your boat, I'd guess there's a big screw/bolt in the middle of the winch. If so, get a big a** screwdriver & unscrew it. Back up a step! Make sure you have a pan, bucket, etc. of solvent (paint thinner works fine) to put all the pieces in. NOW, unscrew that screw (or unpry the C-clip if that's the style you have) and carefully pull the drum off. I doubt you have ball bearings in them but be VERY careful when pulling the drum off as any springs or bearings have a tendency to stick just until they're in direct line of water! You'll then have to remove the pawls & springs at the base of the winch - again VERY carefully cuz the springs tend to...well...spring! Dump all this into the bucket & let it soak while you're cleaning the insides of the winch. Use solvent & a soft cloth (NOT terrycloth, preferably t-shirt material) and/or toothbrush. Pick out all the gunk with a toothpick if you have to but get as much out as possible. Do the same to the stuff in the bucket.Now set everything out on a paper towel, etc. Make sure it's all there, then begin using winch grease (white lithium from Home Depot will do) on everything but the pawls & springs. A light coat will be completely sufficient as too much will just gunk up. Put the springs in (VERY carefully) & use a light machine oil on them. Then put the whole mess back together! Easy, huh?You don't necessarily need to take the whole shebang off the deck to do it either. Good luck and BE CAREFUL! There's nothing worse than hearing that tell tale 'poing!' and seeing a splash out of the corner of your eye.LaDonna
