Ron
Can anyone tell me if swing keels are problematic? Are there through hull fittings associated with them? If so can they leak? I am considering purchasing a C22 with a such a keel and noticed that the steel cable used to crank up the keel has snapped. Is this an easy repair? Is it costly? How do you know when a keel has to be replaced?Thanks for your advice
