Ahoy, All!
My Name is Robert Dobbs and this is my first post. I am the proud new owner of a 2006 Catalina 22 Sport. Like any used sailboat there are a few issues to address. The first issue is, I think, a minor one and I have an idea how to fix it. However, since this is my first Catalina, I thought perhaps it might be a good idea to put this to more experienced sailors. The base of the mast appears to have been damaged by way of dropping to the deck, or a dock, whichever was closer. At any rate, it looks to me that part of the mast, where the retaining bolt would be installed, broke away some time ago. Someone, probably prior to the former owner who had the boat for 2 years, performed a jury rig and fashioned 2 support plates that are through-bolted and attached to the inside of the mast. I will say that it seems a sufficient fix. However, I have this insatiable desire to not only construct in regards to structural integrity, but also it should look presentable. So, this fix that was applied, who knows when, might be satisfactory for means of raising and securing the mast to the mast base plate, but it sure ain't pretty. (Pics Attached) What I'd thought of doing, is to cut about 1-1/2" off the mast to completely remove all holes associated with the old fix. Then, install a mast step. Here's a link to a website that might have one. Mast Steps. The only problem is, you have to know the manufacturer of the mast in order to know what part to order.
Any and all feedback welcome!
) drilled into the fabricated Mast step/foot. I've seen parts like this made for sailboats, but not for the Catalina 22 Sport, so far anyway. Well, there is that website "Rig-Rite", but if you don't know the manufacturer, which I don't, of the mast, they will not help you. They will custom make one for you. You just have to create an accurate drawing, then send it to them. I have no idea what that would cost though, and you won't know till you send the drawing.
