Need a little help here.
The 1985 Catalina 22 parked on it's trailer next to my S21 has been pretty much unattended (by the owner) for about 5 years. I keep an eye on it for him because, well because it's a sailboat!
Anyway the last time I looked at it the cockpit was full of water (mixed with leaves and misc. dirt). The boat has 2 drains, port & starboard, up front in the cockpit sole. I cleared the leaves to facilitate drainage, but resorted to running an old piece of 1/8th" shroud down the port drain to clear it. Seemed to work for a while, but as I poked it further into the drain - my piece of shroud wire came up the starboard drain!!
Evidently they're connected and for all I can tell empty somewhere in the keel recess under the boat.
It's dark so I can't tell for sure, but it doesn't look like the drains are working and the cockpit is still 1/2 full of water.
Any ideas? Happened to anyone on the forum? Got a solution?
Failing any good ideas, in the daylight, I may plug one drain hole and plunger the other.
My S21 has 2 cockpit drain holes (scuppers?) in the transom, so I'm not sure what I'm up against on this Catalina 22.
Still looking for a couple of good sailing days in West Michigan,
David.
David.
