Is the teak compression post hollow?
I am going to run new wires in the mast including cable for new wind transducer.
I am also putting in new depth speed temp transducer.
I need to route the 2 transducer cables to the same ITC-5 through which I get the signals to the Seatalkng network. I also need a way to disconnect and reconnect the mast wires at the mast base.
Can I route wires through the compression post?
Suggestions welcome.
