Fuel burn & rpms
I know there is much opinion that a diesel must turn at a high rpm [80 percent of rated max], however there is another side to consider.The same small diesels also run generators, and are set to run continously at 1800 and rack up thousands of hours.I talked to Kubota and was told the rpm is not the important factor, but the load. A diesel needs to be run at enought load to maintain heat. As long as this is done, the rpm is of little consequence. Running a slightly oversized prop reduces the needed rpm to produce hull speed and results in less noise, vibration, and fuel burn.Running an undersized prop is like running your car in second gear. I have been running props on small diesels that allow about 70/80 percent of max rpms for years with excellent results. Just anoher opinion Ron B
